95 05 165
95 05 165
    KNIPEX(凯尼派克)
    缆线 切割器 圆形 剪 6.50"(165.1mm)
95 05 165 数据手册
95 05 165 Cable Shears ● ● ● ● ● ● ● ● ● ● ● Article No. 95 05 165 EAN 4003773019596 Head polished Handles plastic coated Not suitable for steel wire and hard drawn copper conductors Precision ground, hardened blades No crushing, slight deformation of the cable only Guard prevents operators’ fingers being pinched Adjustable bolted joint Shears body: surgical steel, stainless, vacuum-hardened Handles: plastic, impact-proof Cuts cables up to 10 mm dia. / 24 mm² With opening spring and locking device Blades made of stainless steel Oil-hardened and tempered Cutting capacity copper cable, multiple10 stranded (diameter) Ø mm Cutting capacity copper cable, multiple- 24 stranded mm² AWG 3 Length mm 165 Net weight g 111 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 05 165 价格&库存
很抱歉,暂时无法提供与“95 05 165”相匹配的价格&库存,您可以联系我们找货
