00 21 05 LE
00 21 05 LE
    KNIPEX(凯尼派克)
    KNIPEX - 00 21 05 LE - Tool Case, ABS, 200 mm Height, 465 mm Width, 410 mm Depth
00 21 05 LE 数据手册
00 21 05 LE Tool Case "Basic" empty ● ● ● ● ● ● ● ● ● ● Article No. 00 21 05 LE EAN 4003773056904 Dimension exterior (interior) width mm mm 465 (440) Dimension exterior (interior) height mm mm 200 (180) Dimension exterior (interior) depth mm mm 410 (350) Net weight g 5680 Heavy duty ABS material, black Circumferential aluminium frame with D-shape rings for the shoulder strap (included) 3-digit lock and two flip-locks for fixation of the cover Strong, ergonomic handle Metal hinges Lid holder with hinge-joint mechanism Document compartment in the cover Removable tool board in the lid with nine push-in compartments and an elastic loop on the lid side; with ten slim and one large push in compartments on the bottom side Base tray, height 55 mm, can be subdivided by inserts; cover plate with 12 large push-in compartments and a flat compartment, can be fixed by press button Load capacity: 15 kg technical change and errors excepted Accessories Article No. EAN 00 21 99 V05 4003773082088 Shoulder strap for tool bags and tool cases KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
00 21 05 LE 价格&库存
很抱歉,暂时无法提供与“00 21 05 LE”相匹配的价格&库存,您可以联系我们找货
