16 95 02 SB
16 95 02 SB
    KNIPEX(凯尼派克)
    ERGOSTRIP METRIC SIZES LEFT HND
16 95 02 SB 数据手册
16 95 02 SB KNIPEX ErgoStrip® Universal Stripping Tool ● ● ● ● ● ● ● ● ● ● Article No. 16 95 02 SB EAN 4003773082910 For the fast and precise stripping of all common round and dampproof installation cables (e.g. NYM cable 3 x 1.5 mm² up to 5 x 2,5 mm²), data cable (e.g. twisted pair) and coax cable Innovative, ergonomic pistol grip design for easy cutting, stripping and longitudinal cut of the sheath Conical, slimmed down tool ends for better access in confined areas Stripping device for cross-sections 0.2 / 0.3 / 0.8 / 1.5 / 2.5 / 4 mm² Simplified insertion of single wires for stripping using location ridges With opening spring and locking device Easy insertion of coax and data cable thanks to opening aid Multi-component design with a soft plastic zone for comfortable use and a secure grip Housing made from stable glass fibre reinforced plastic For left-handers Stripping capacities round cable (diameter) 8 - 13 Ø mm Wire stripping value for conductors and strands mm² 0,2 - 4,0 Wire stripping value for data cable CAT 5 - 7, Twisted pair (UTP/STP) Stripping of a NYM cable With concealed cutter in overhanging thumb rest on the side for convenient lengthwise cut Wire stripping on single conductors Stripping of a data cable stripping of a coax cable Stripping of a coax cable Stripping capacities for coax cable (diameter) 4,8 - 7,5 Ø mm Length mm 135 Net weight g 75 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
16 95 02 SB 价格&库存
很抱歉,暂时无法提供与“16 95 02 SB”相匹配的价格&库存,您可以联系我们找货
