48 11 J2
48 11 J2
    KNIPEX(凯尼派克)
    KNIPEX - 48 11 J2 - J2 Precision Straight Tipped Internal Circlip Pliers with Non-slip Plastic Coate...
48 11 J2 数据手册
48 11 J2 Precision Circlip Pliers for internal circlips in bore holes ● ● ● ● ● ● With inserted tips for reliable work Heavy duty in continuous operation: up to 10 times longer service life compared to turned tips Bolted joint: precise, zero backlash operation of pliers Non-slip plastic coating on the handles Pliers body: chrome vanadium electric steel, forged, oil-hardened Inserted tips: spring steel wire, drawn Style:DIN 5256 C, straight tips ❍ High precision quality Easy and reliable assembly: form-fitting inserted and pressed-in tips made of high-density spring steel offer a high level of protection against excessive stress and strain, e.g. when removing stuck rings. The large supporting surfaces and the position of the tips make it more difficult for the rings to bounce off. Precision and durability High-density spring steel with a score-free surface is used for the tips. This increases the tips' resistance to dynamic and static strain. The tips are 30 % more stable than conventional pliers when subjected to one-off overloading while still allowing good accessibility during assembly. Subjected to dynamic strain, the tips' resistance capacity is up to 10 times greater! The tips on the precision circlip pliers are non-detachable! KNIPEX circlip pliers with overexpansion guard For the standardized fitting of circlips in the industrial serial production. Particularly manufacturers of sensitive, safety-relevant components (e.g. brakes or gears) highly appreciate the compliance of DIN 471 and 472. The mounting of circlip rings in this case requires pliers with overexpansion guard or a cone. KNIPEX Circlip Pliers with overexpansion guard meet the requirements and furthermore offer a superior durability. Article No. 48 11 J2 EAN 4003773048534 Pliers grey atramentized Handles with non-slip plastic coating Style 1 Size of bore Ø mm 19 - 60 Style straight tips Ø mm 19 - 60 Tips (diameter) Ø mm 1,8 Length mm 180 Net weight g 175 Tight fit through compression technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
48 11 J2 价格&库存
很抱歉,暂时无法提供与“48 11 J2”相匹配的价格&库存,您可以联系我们找货
