70 26 160
70 26 160
    KNIPEX(凯尼派克)
    KNIPEX - 70 26 160 - Cutter, Diagonal, 160 mm, Edge, 4 mm, 62 °
70 26 160 数据手册
70 26 160 Diagonal Cutter ● ● ● ● ● ● ● ● Article No. 70 26 160 EAN 4003773018223 Pliers chrome plated Handles insulated with multicomponent grips, VDEtested Style 2 Head Insulation standard IEC 60900 DIN EN 60900 Cutting capacities soft wire (diameter) Ø mm 4,0 Length mm 160 Net weight g 216 The indispensable diagonal cutter for all-round use High-quality material and precise workmanship for long service life Precision cutting edges for soft and hard wire Clean cutting of thin copper wires, also at the cutting-edge tips Cutting edges additionally induction hardened, cutting edge hardness approx. 62 HRC Narrow head style for use in confined areas Vanadium electric steel, forged, multi stage oil-hardened With elongated cutting edge Slim head style and precise cut at blade tips: Advantageous when working in confined areas technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
70 26 160 价格&库存
很抱歉,暂时无法提供与“70 26 160”相匹配的价格&库存,您可以联系我们找货
