71 22 200
71 22 200
    KNIPEX(凯尼派克)
    KNIPEX - 71 22 200 - 200mm 20° Angled Head Bolt Cutters with Slim Two Colour Dual Component Handles
71 22 200 数据手册
71 22 200 KNIPEX CoBolt® Compact Bolt Cutter, angled ● ● ● ● ● Precision cutting edges for soft and hard wire as well as piano wire Cuts bolts, nails, rivets, etc. up to 5.2 mm dia. Most efficient joint design ensures exceptional cutting performance with little effort Cutting edges additionally induction hardened, cutting edge hardness approx. 64 HRC Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened Style:20° angled head with joint bar on one side and side cutter for almost flush cutting, with space for gripping ❍ ● ● With slim multi-component grips without collar for better handling and easier transport Opening spring and locking device are integrated in the handles also for comfortable work and protected transport 60 % less effort required compared to conventional high-leverage diagonal cutters The ingenious lever-action mechanism ensures an extremely favourable lever ratio with very little friction. The cutting force over 30 times higher than the hand force applied. Article No. 71 22 200 EAN 4003773066873 Pliers black atramentized Handles with slim multicomponent grips Style 2 Cutting capacities medium hard wire (diameter) Ø mm 5,2 20° angled head with single-sided joint bar and diagonal cutting edge for flush cutting; with space for gripping Cutting capacities hard 4,0 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 3,6 Cutting capacities soft wire (diameter) Ø mm 6,0 Length mm 200 Net weight g 375 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
71 22 200 价格&库存
很抱歉,暂时无法提供与“71 22 200”相匹配的价格&库存,您可以联系我们找货
