87 01 400
87 01 400
    KNIPEX(凯尼派克)
    KNIPEX - 87 01 400 - 400mm Cobra Water Pump Pliers with Plastic Coated Handles
87 01 400 数据手册
87 01 400 KNIPEX Cobra® XL Pipe Wrench and Water Pump Pliers ● ● ● ● ● ● ● ● Greater gripping capacity but much lower weight than comparable pipe wrenches Fast push-button adjustment directly on the workpiece, no unintentional slipping of the joint Fine adjustment for optimum adaptation to different sizes of workpieces and a comfortable handle width Self-locking on pipes and nuts: no slipping on the workpiece and low handforce required Gripping surfaces with special hardened teeth, teeth hardness approx. 61 HRC: high wear resistance and stable gripping Box-joint design for high stability due to double guide Guard prevents operators’ fingers being pinched Chrome vanadium electric steel, forged, multi stage oil-hardened Both the KNIPEX Cobra® XL and XXL offer the performance and comfort of water pump pliers while being lighter in weight and having a greater gripping capacity than comparable pipe wrenches. The Cobra® XL can e.g. grip a 2“ pipe fitting and weighs 50 % less than a 2“ pipe wrench, which has a much lower gripping capacity. With its handy length of 400 mm, the Cobra® XL also fits into a plumber's tool kit. The Cobra® XXL comes along with the weight of a 2“ pipe wrench but offers a back-up gripping capacity up to 4 1/2“. Article No. 87 01 400 EAN 4003773005636 Pliers grey atramentized Head polished Handles plastic coated Adjustment positions 27 Capacity for pipes, inches (diameter) Ø Inch 3 1/2 Capacities for pipes (diameter) Ø mm 90 Fine adjustment by pushing a button: fast and comfortable. Capacities for nuts mm 95 Length mm 400 Net weight g 1214 technical change and errors excepted Spare Parts Article No. EAN 87 09 400 4003773034391 Range of spare parts adjustment for 87 400 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
87 01 400 价格&库存
很抱歉,暂时无法提供与“87 01 400”相匹配的价格&库存,您可以联系我们找货
