87 22 250
87 22 250
    KNIPEX(凯尼派克)
    KNIPEX - 87 22 250 - Water Pump, Plier, Slip Joint, 50 mm, Jaw, 250 mm, Length
87 22 250 数据手册
87 22 250 KNIPEX Cobra® QuickSet Hightech Water Pump Pliers ● ● ● ● ● ● ● Fully open, push, grab! Additional fast adjustment on the workpiece by sliding the pliers handle Combines the proven, reliable locking of the hinge bolt with an additional push function which makes it easier to work in very confined and inaccessible areas The adjustment directly on the workpiece is possible by simply sliding the pliers handle Reliable locking of the hinge bolt with the first workload. The gripping width of the pliers is then fixed and can only be adjusted by pressing the button. To re-activate the sliding function, the hinge bolt must be released by pressing the push button and the pliers must be completely opened again Chrome vanadium electric steel, forged, multi stage oil-hardened The Cobra® QuickSet combines all proven properties of the KNIPEX Cobra® with an additional push on function which makes it easier to work in very confined and inaccessible areas. Adjustment directly on the workpiece is possible by simply sliding the pliers handle. The hinge bolt locks itself with the first workload. The gripping width of the pliers is then fixed and can only be adjusted by pressing the button. The hinge bolt must be released by pressing the button and the pliers must be completely opened once to activate the QuickSet function again. Article No. 87 22 250 EAN 4003773077794 Pliers grey atramentized Head polished Handles with slim multicomponent grips Adjustment positions 25 Capacity for pipes, inches (diameter) Ø Inch 2 Capacities for pipes (diameter) Ø mm 50 Press the button – open pliers completely Position jaw – simply slide and close pliers Hinge bolt locks itself with the first workload Capacities for nuts mm 46 Length mm 250 Net weight g 366 technical change and errors excepted Spare Parts Article No. EAN 87 29 01 4003773079002 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
87 22 250 价格&库存
很抱歉,暂时无法提供与“87 22 250”相匹配的价格&库存,您可以联系我们找货
