95 22 165
95 22 165
    KNIPEX(凯尼派克)
    KNIPEX - 95 22 165 - Cable Cutter, 15mm Capacity, Opening Spring, Aluminium and Copper Cables, 165mm...
95 22 165 数据手册
95 22 165 Cable Shears with opening spring ● ● ● ● ● ● ● ● For cutting copper and aluminium single conductors as well as multiple stranded cables Not suitable for steel wire and hard drawn copper conductors Precision ground, hardened blades Clean and smooth cut without crushing and deformation Easy cutting with one-hand operation Guard prevents operators’ fingers being pinched Adjustable bolted joint, self-retaining screw High-grade special tool steel, forged, oil-hardened Style:internal opening spring, protected and captive ❍ Article No. 95 22 165 EAN 4003773069812 Tool burnished Handles with multi-component grips Style 2 Cutting capacity copper cable, multiple15 stranded (diameter) Ø mm Cutting capacity copper cable, multiple- 50 stranded mm² AWG 1/0 Length mm 165 Net weight g 254 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 22 165 价格&库存
很抱歉,暂时无法提供与“95 22 165”相匹配的价格&库存,您可以联系我们找货
