97 90 09
97 90 09
    KNIPEX(凯尼派克)
    KNIPEX - 97 90 09 - Box of Assorted Crimping Ferrule for use with 97 53 04 Crimping Pliers
97 90 09 数据手册
97 90 09 Crimp Assortment for end sleeves (ferrules) ● ● ● ● ● ● Article No. 97 90 09 EAN 4003773028574 200 end sleeves each mm² 0,5 / 0,75 / 1,0 / 1,5 / 2,5 100 end sleeves each mm² 4,0 / 6,0 50 end sleeves each mm² 10,0 Net weight g 1420 In a TANOS MINI-systainer® (solid plastic box) T-Loc fastener for one-handed operation: open or close the systainer® with one turn and connect to a second systainer® Opening when connected: fast and simple access to content without disconnecting Two stackable plastic inserts with 6 trays each for connectors With an assortment of end sleeves (ferrules) with/without collar With Self-Adjusting Crimping Pliers for End Sleeves (ferrules) 97 53 04 technical change and errors excepted systainer® is a registered trademark of TANOS GmbH Content 97 90 09 (9) Article No. 97 53 04 Quantity Self-Adjusting Crimping Pliers for End Sleeves (ferrules), with lateral access 1 End Sleeves (ferrules) with collar, 14 / 8 mm 200 0,5 mm² End Sleeves (ferrules) with collar, 14 / 8 mm 200 0,75 mm² End Sleeves (ferrules) with collar, 14 / 8 mm 200 1 mm² End Sleeves (ferrules) with collar, 14 / 8 mm 200 1,5 mm² End Sleeves (ferrules) with collar, 14 / 8 mm 200 2,5 mm² End Sleeves (ferrules) with collar, 17 / 10 mm 100 4 mm² KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 End Sleeves (ferrules) with collar, 20 / 12 mm 100 6 mm² End Sleeves (ferrules) with collar, 22 / 12 mm 50 10 mm² KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
97 90 09 价格&库存
很抱歉,暂时无法提供与“97 90 09”相匹配的价格&库存,您可以联系我们找货
