97 90 25
97 90 25
    KNIPEX(凯尼派克)
    KNIPEX - 97 90 25 - Crimp Assortment for Cable Connectors
97 90 25 数据手册
97 90 25 Crimp Assortment for cable connectors ● ● ● ● ● ● Article No. 97 90 25 EAN 4003773076971 Net weight g 1150 In a TANOS MINI-systainer® (solid plastic box) T-Loc fastener for one-handed operation: open or close the systainer® with one turn and connect to a second systainer® Opening when connected: fast and simple access to content without disconnecting Two stackable plastic inserts with 6 trays each for connectors With an assortment of standard cable connectors With crimping pliers 97 22 240 technical change and errors excepted Content 97 90 25 (13) Article No. 97 22 240 Quantity Crimping Pliers 1 Non-Insulated Blade Terminal Sockets, 6,3x0,8 mm 25 0,5-1,5 mm² Non-Insulated Blade Terminal Sockets, 6,3x0,8 mm 25 1,0-2,5 mm² Blade Terminal Sockets, 6,3x0,8 mm 25 0,5-1 mm² Blade Terminal Sockets, 6,3x0,8 mm 25 1,5-2,5 mm² Blade Terminal Sockets, 6,3x0,8 mm 25 4,0-6,0 mm² Blade Terminal Plugs, 6,3x0,8 mm 25 0,5-1,0 mm² Blade Terminal Plugs, 6,3x0,8 mm 25 1,5-2,5 mm² Cable Connectors, eye type, Ø 4 mm 25 0,5-1 mm² Cable Connectors, eye type, Ø 4 mm 25 1,5-2,5 mm² Butt Connectors, insulated, Red 25 0,5-1 mm² Butt Connectors, insulated, Blue 1,5-2,5 mm² 25 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 Butt Connectors, insulated, Yellow 25 4,0-6,0 mm² KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
97 90 25 价格&库存
很抱歉,暂时无法提供与“97 90 25”相匹配的价格&库存,您可以联系我们找货
