00 21 19 LB S
00 21 19 LB S
    KNIPEX(凯尼派克)
    KNIPEX - 00 21 19 LB S - Tool Kit, Electrical, Case, Assorted, 52 Piece, L-BOXX Series
00 21 19 LB S 数据手册
00 21 19 LB S KNIPEX L-BOXX® Plumbing 52 parts ● ● ● ● ● ● ● ● ● Article No. 00 21 19 LB S EAN 4003773081630 Net weight g 9400 Equipped with 52 brand name quality tools, some VDE tested according to DIN EN 60900 Several boxes can be securely joined together Flexible inner partitions With two-part tool holder made of hard-wearing polyester fabric Tool holders are connected to each other using hook-and-loop Handle can be lowered into a hollow in the lid to save space Ergonomically shaped handles with additional moulded recess on the side for flexible, convenient handling Dimensions, exterior (W x H x D): 442 x 151 x 357 mm; dimensions, interior (W x H x D): 375 x 107 x 311 mm Strong box made of impact- and shock-proof ABS plastic technical change and errors excepted L-BOXX® is a registered trademark of Sortimo International GmbH Content 00 21 19 LB S (25) Article No. Quantity Nominal size 00 11 01 Knipex KNIPEX TwinKey®, for all standard cabinets and shut-off systems 26 16 200 Knipex Snipe Nose Side Cutting Pliers, (Stork Beak Pliers) 1 74 06 180 Knipex High Leverage Diagonal Cutter 1 86 03 250 Knipex Pliers Wrench, pliers and a wrench in a single tool 1 Knipex KNIPEX Cobra , Hightech Water 1 Pump Pliers 87 01 400 Knipex KNIPEX Cobra® XL, Pipe Wrench 1 and Water Pump Pliers 98 20 35 Knipex Screwdrivers for slotted screws 1 3,5 x 100 mm 98 20 55 Knipex Screwdrivers for slotted screws 1 5,5 mm x 125 mm 98 26 15 Knipex Screwdriver for Torx® screws 1 TX15 98 26 20 Knipex Screwdriver for Torx® screws 1 TX20 98 26 25 Knipex Screwdriver for Torx® screws 1 TX25 98 24 01 Knipex Screwdriver for cross recessed screws, Phillips® 1 PH 1 98 24 02 Knipex Screwdriver for cross recessed screws, Phillips® 1 PH 2 361 252 1 Rennsteig Electrician’s Chisel 1 250 x 10 mm 005655 Wera Voltage detector, single-pole, 247 1 0,5 x 3,0 x 70 mm 004018 Wera 8100 SA 8 Zyklop set of metal ratchets, 28 parts 1 1/4" 003760 Wera Joker open-end wrench 1 10 x 13 mm 022086 Wera set of hex key wrenches 1 1,5 - 10 mm 90958 Heyco Express key 1 17 x 19 mm; M 10 16640003 Heyco Safety cutter knife 1 18 mm 101-0300 Picard Locksmith’s hammer 1 300 g 340 250 1 Rennsteig Mason’s Chisels 1 250 mm 02281 Stabila spirit level type 70 1 30 cm 71510-000 Picard Metre ruler (yardstick) 1 2m 6135-0 Zenten pipe cutter 1 3 - 35 mm / 1/8 - 1 1/2" 87 01 250 1 ® 200 mm 250 mm KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
00 21 19 LB S 价格&库存
很抱歉,暂时无法提供与“00 21 19 LB S”相匹配的价格&库存,您可以联系我们找货
