11 05 160
11 05 160
    KNIPEX(凯尼派克)
    KNIPEX - 11 05 160 - Wire Stripping Tool, 7 AWG Capacity, 160 mm Overall, For 5 mm Diameter Cables
11 05 160 数据手册
11 05 160 Insulation Stripper ● ● ● Article No. 11 05 160 EAN 4003773039570 Pliers chrome plated Handles with multi-component grips Style 0 For single, multiple and fine stranded conductors with plastic or rubber insulation up to 5.0 mm dia. or 10 mm² cable cross-section Easy adjustment to the required diameter of solid or stranded wire with knurled screw and lock nut Special tool steel, forged, oil-hardened Head Stripping capacities in square millimetres mm² 10,0 Nominal size 160 mm Stripping capacities (diameter) Ø mm 5,0 AWG 7 Length mm 160 Net weight g 157 technical change and errors excepted Spare Parts Article No. EAN 11 09 01 4003773052326 Set of spare parts (screw and nut) for 11 160 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
11 05 160 价格&库存
很抱歉,暂时无法提供与“11 05 160”相匹配的价格&库存,您可以联系我们找货
