12 12 10
12 12 10
    KNIPEX(凯尼派克)
    工具 单层剥除器,可调 用于 7 ~ 13 AWG
12 12 10 数据手册
12 12 10 Precision Insulation Stripper with adapted blades ● ● ● ● ● ● Form-fit stripping also of difficult-to-remove insulating materials made of PTFE, silicone, Radox®, Kapton® and rubber; multi-layer too A second pair of blades holds the remaining insulation reliably in place Replaceable shaped blade adapted precisely to the respective conductor cross-section With length stop for constant stripping length during repetitive work Pliers body: steel Blade: special tool steel, oil-hardened Precisely and reliably Two pairs of blades (1) cut the insulation to a complete extent. Then the blade pairs move apart, and thus the insulation is removed form-fit (2). The pliers open automatically after the stripping procedure. Principle of operation with adapted blades Properly and precise stripping with an annular cut through the complete insulation. This is particularly important with conductors, which must be stripped precisely. This works without any problem even with difficult insulating materials made of PTFE, Radox® and multilayer insulations. Article No. 12 12 10 EAN 4003773049012 Pliers burnished Handles with multi-component grips Stripping capacities in square millimetres mm² 2,5 / 4,0 / 6,0 / 10,0 AWG 13 - 7 Length mm 195 Net weight g 445 Precise cutting of the Positive stripping insulation to a complete thanks to precise shape extent of the blades technical change and errors excepted Kapton® is a registered trademark of E. I. du Pont de Nemours and Company Radox® is a registered trademark of Huber & Suhner AG KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 Spare Parts Article No. EAN 12 19 10 4003773049050 1 set of spare blades for 12 12 10 12 19 91 4003773079439 Set of springs for 12 12 xx with adapted blades Accessories Article No. EAN 12 19 90 4003773078982 Length stop for 12 12 xx with adapted blades KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
12 12 10 价格&库存
很抱歉,暂时无法提供与“12 12 10”相匹配的价格&库存,您可以联系我们找货
