12 21 180
12 21 180
    KNIPEX(凯尼派克)
    工具 单层剥除器,可调 用于 10 ~ 20 AWG
12 21 180 数据手册
12 21 180 Insulation Stripper with adapted blades ● ● ● ● ● ● ● Article No. 12 21 180 EAN 4003773000815 Pliers black lacquered Handles with plastic grips Stripping capacities in square millimetres mm² 0,5-0,75 / 1,0 / 1,5 / 2,5 / 4,0 / 6,0 AWG 20-19/ 17/15/ 13/11/ 10 Length mm 180 Net weight g 366 With replaceable blades for 4 or 6 different conductor cross-sections Leave wire undamaged thanks to precision-ground blade shapes, even multi-stranded conductors are stripped gently During stripping, the wire is held firmly by clamping jaws With length stop for constant stripping length during repetitive work A spring leads the stripper back to the starting position Pliers body: aluminium Blade: special tool steel, oil-hardened technical change and errors excepted Spare Parts Article No. EAN 12 29 180 4003773022152 1 pair of spare blades for 12 21 180 with adapted blades KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
12 21 180 价格&库存
很抱歉,暂时无法提供与“12 21 180”相匹配的价格&库存,您可以联系我们找货
