35 32 115 ESD
Electronics Pliers ESD
Precision pliers for fine assembly work, e g. in electronics and fine
mechanics
Load-optimised for a more direct feel when working
For gripping, holding and bending
Electrically discharging handles - dissipative
Sturdy, zero backlash box joint
Smooth ground gripping surfaces
Soft transitions; no sharp edges
Low-friction double spring for gentle and even opening
The mirror polish together with a fine film of oil offer effective rust
protection - no circuit faults caused by peeling chrome from plated
tools
Narrow sleeves pulled up to the head of the pliers enable the tool to
be guided securely and comfortably, also between thumb and index
finger
With two-colour dual component grips, black/grey
Ball bearing chrome steel
ESD pliers (electrostatic discharge)
electrostatic energy is discharged through the handles in a gradual and controlled manner
which protects components endangered by electrostatic discharge
in accordance with applicable standards, e.g. IEC TR 61 340-5, DIN EN 61 340-5, SP Method 2472
Article No.
35 32 115 ESD
EAN
4003773024859
Head
mirror polished
Handles
with multi-component
grips
Style
3
B mm
22,5
D mm
7
E mm
2,0
F mm
1,0
A mm
11
Length mm
115
Net weight g
70
technical change and errors excepted
KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany
info@knipex.de | www.knipex.de
1
很抱歉,暂时无法提供与“35 32 115 ESD”相匹配的价格&库存,您可以联系我们找货
