74 06 160
74 06 160
    KNIPEX(凯尼派克)
    160mm Length High Leverage Diagonal Cutter with 3.4mm Capacity
74 06 160 数据手册
74 06 160 High Leverage Diagonal Cutter ● ● ● ● ● With integrated forged axle for heaviest duty Suitable for all types of wire including piano wire High cutting performance with minimum effort due to optimum coordination of the cutting edge angle and transmission ratio Precision cutting edges additionally induction-hardened, cutting edge hardness approx. 64 HRC Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened 20 % less effort required compared to conventional diagonal cutters of the same length. With integrated forged joint axle. Article No. 74 06 160 EAN 4003773040705 Pliers chrome plated Handles insulated with multicomponent grips, VDEtested Style 0 Head Insulation standard IEC 60900 DIN EN 60900 Cutting capacities medium hard wire (diameter) Ø mm 3,4 Cutting capacities hard 2,5 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 2,0 Length mm 160 Net weight g 215 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
74 06 160 价格&库存
很抱歉,暂时无法提供与“74 06 160”相匹配的价格&库存,您可以联系我们找货
