87 26 250
KNIPEX Cobra® VDE Hightech Water Pump Pliers, insulated
Adjustment by shifting one jaw directly on to the workpiece: fast,
reliable and comfortable handling
Opening at the touch of a button apart from the workpiece
Fine adjustment for optimum adaptation to different sizes of
workpieces and a comfortable handle width
Good access to the workpiece due to slim size of head and joint area
Self-locking on pipes and nuts: no slipping on the workpiece and low
handforce required
Gripping surfaces with special hardened teeth, teeth hardness
approx. 61 HRC: high wear resistance and stable gripping
Box-joint design for high stability due to double guide
Guard prevents operators’ fingers being pinched
Chrome vanadium electric steel, forged, multi stage oil-hardened
The adjustment action to adapt to the workpiece is easy and reliable with the KNIPEX Cobra® VDE: place the upper gripping jaw of the opened
pliers on the workpiece, push pliers to close, done!
Article No.
87 26 250
EAN
4003773071495
Pliers
chrome plated
Handles
insulated with multicomponent grips, VDEtested
Quick setting without
using a push-button
Just push the pliers
handle to adjust!
Head
Insulation standard
IEC 60900 DIN EN 60900
Adjustment positions
24
Capacity for pipes,
inches (diameter) Ø
Inch
2
Capacities for nuts mm 46
Capacities for pipes
(diameter) Ø mm
50
Length mm
250
Net weight g
340
technical change and errors excepted
Spare Parts
Article No.
EAN
87 29 01
4003773079002
KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany
info@knipex.de | www.knipex.de
1
很抱歉,暂时无法提供与“87 26 250”相匹配的价格&库存,您可以联系我们找货
