90 22 10 BK
90 22 10 BK
    KNIPEX(凯尼派克)
    KNIPEX - 90 22 10 BK - Pipe Cutter, Plastic Tube, 72 mm, 50 mm, BiX Series
90 22 10 BK 数据手册
Product information 90 22 10 BK ● Clever pipe cutter: Cuts pipes without shavings and fits comfortably in the hand ● Can cut high-temperature plastic drain pipes and electrical conduits in next to no time ● Can be used to cut sealing sleeves during final assembly – close to the wall, standard-compliant KNIPEX BiX® Cutters for plastic pipes and sealing sleeves ● Cuts unreinforced plastic pipes from Ø 20 to 50 mm with a wall thickness of up to 2.4 mm ● Cuts soft plastic pipes and those with foamed cores from Ø 20 to 50 mm with a wall thicknesses of up to 3.5 mm ● Cuts sealing sleeves approx. 2-3 mm from the wall ● Cuts pipes quickly, cleanly and without shavings ● Rotatable knife block for cutting plastic pipes (blade in the middle) and sealing sleeves (blade outside) ● With locking mechanism for safe transport ● Two spare blades integrated in the tool ● Tool made of stable, reinforced plastic, die-cast zinc blade unit ● Blades made of special surgical stainless steel – Made in Solingen General Article No. 90 22 10 BK EAN 4003773087311 Weight 108 g Dimensions 72 x 50 x 40 mm REACH compliant no RohS compliant no Technical details Cutting values for HT and plastic pipes Ø mm Ø 20 – 50 mm Cutting values for sealing sleeves Ø mm Ø 20 – 50 mm Classification eCl@ss 5.1.4 21040601 ETIM 5.0 EC000148 ETIM 6.0 EC000148 proficl@ss 6.0 AAB927c006 Spare Parts 90 22 10 E01 Spare blades for 90 22 10 BK, technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 16.09.2021 | page 1 7 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 16.09.2021 | page 2 7 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 16.09.2021 | page 3 7 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 16.09.2021 | page 4 7 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 16.09.2021 | page 5 7 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 16.09.2021 | page 6 7 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 16.09.2021 | page 7 7
90 22 10 BK 价格&库存
很抱歉,暂时无法提供与“90 22 10 BK”相匹配的价格&库存,您可以联系我们找货
