13 96 200 T
13 96 200 T
    KNIPEX(凯尼派克)
    KNIPEX - 13 96 200 T - Plier, Electrician, 200 mm Length
13 96 200 T 数据手册
13 96 200 T Pliers for Electrical Installation with tether attachment point ● ● ● ● ● ● ● ● ● ● ● ● Article No. 13 96 200 T EAN 4003773081425 Pliers chrome plated Multifunctional pliers for the electrical installation; to grip flat and round material, for bending, deburring, cutting cable, stripping and crimping end sleeves (ferrules) 6 functions in one pair of pliers Smooth surfaces near the tips grip single cores without damaging them; serrated gripping surfaces and pipe grip for gripping flat and round material Clear-cut outside edge on the jaw for working on flush-mounted junction boxes and deburring feed-through holes Stripping holes for conductors of 0.75 - 1.5 mm² and 2.5 mm² Crimp die for wire-end ferrules 0.5 - 2.5 mm² Cable shears with (induction-hardened) precision cutting edges for copper and aluminium cables up to 5 x 2.5 mm² / dia. 15 mm Gripping, without opening the pliers completely (intelligent latching mechanism in the spring assisted version). The cutting edge remains closed and protected Slim dimensions for easy access Bolted joint: precise, zero backlash operation of pliers High-grade special tool steel, forged, multi stage oil-hardened Pliers with integrated, insulated tether attachment point for a tool tether Head Handles insulated with multicomponent grips, VDEtested with integrated insulated tether attachment point for a tool tether Insulation standard IEC 60900 DIN EN 60900 Cutting capacity copper cable, multiple- 50 stranded mm² Cutting capacity copper cable, multiple15 stranded (diameter) Ø mm Stripping capacity for cross-sections mm² 0,75 - 1,5 + 2,5 Capacity in square millimetres mm² 0,5 - 2,5 AWG 1/0 Length mm 200 Net weight g 277 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
13 96 200 T 价格&库存
很抱歉,暂时无法提供与“13 96 200 T”相匹配的价格&库存,您可以联系我们找货
