35 32 115
35 32 115
    KNIPEX(凯尼派克)
    电子设备 钳子 平头 平滑 4.50"(114.3mm)
35 32 115 数据手册
35 32 115 Electronics Pliers ● ● ● ● ● ● ● ● ● ● Article No. 35 32 115 EAN 4003773035121 Head mirror polished Handles with multi-component grips Style 3 B mm 22,5 D mm 7 E mm 2,0 F mm 1,0 A mm 11 Nominal size 115 mm Length mm 115 Net weight g 72 Precision pliers for fine assembly work, e g. in electronics and fine mechanics Load-optimised for a more direct feel when working For gripping, holding and bending Sturdy, zero backlash box joint Smooth ground gripping surfaces Soft transitions; no sharp edges Low-friction double spring for gentle and even opening The polish or mirror polish (only finish 2) together with a fine film of oil offer effective rust protection - no circuit faults caused by peeling chrome from plated tools Narrow sleeves pulled up to the head of the pliers enable the tool to be guided securely and comfortably, also between thumb and index finger Ball bearing chrome steel technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
35 32 115 价格&库存
很抱歉,暂时无法提供与“35 32 115”相匹配的价格&库存,您可以联系我们找货
