74 06 200 T
74 06 200 T
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 8.00"(203.2mm)
74 06 200 T 数据手册
74 06 200 T High Leverage Diagonal Cutter with tether attachment point ● ● ● ● ● ● With integrated forged axle for heaviest duty Suitable for all types of wire including piano wire High cutting performance with minimum effort due to optimum coordination of the cutting edge angle and transmission ratio Precision cutting edges additionally induction-hardened, cutting edge hardness approx. 64 HRC Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened Pliers with integrated, insulated tether attachment point for a tool tether 20 % less effort required compared to conventional diagonal cutters of the same length. With integrated forged joint axle. Article No. 74 06 200 T EAN 4003773081494 Pliers chrome plated Handles insulated with multicomponent grips, VDEtested with integrated insulated tether attachment point for a tool tether Head Style 0 Insulation standard IEC 60900 DIN EN 60900 Cutting capacities medium hard wire (diameter) Ø mm 4,2 Cutting capacities hard 3,0 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 2,5 Nominal size 200 mm Length mm 200 Net weight g 311 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
74 06 200 T 价格&库存
很抱歉,暂时无法提供与“74 06 200 T”相匹配的价格&库存,您可以联系我们找货
