74 12 180
74 12 180
    KNIPEX(凯尼派克)
    KNIPEX - 74 12 180 - Cutter, Precision, 180 mm, Diagonal, 3.8 mm, 64 °
74 12 180 数据手册
74 12 180 High Leverage Diagonal Cutter ● ● ● ● For very tough, continuous use High cutting performance with minimum effort due to optimum coordination of the cutting edge angle and transmission ratio Precision cutting edges additionally induction hardened (cutting edge hardness approx. 64 HRC), for all sorts of wire including piano wire Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened Style:with opening spring; to be activated if required ❍ 20 % less effort required compared to conventional diagonal cutters of the same length. With integrated forged joint axle. Article No. 74 12 180 EAN 4003773060192 Pliers black atramentized Head polished Handles with multi-component grips Style 1 Cutting capacities medium hard wire (diameter) Ø mm 3,8 74 12: opening spring in deactivated position Cutting capacities hard 2,7 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 2,2 Length mm 180 Net weight g 273 technical change and errors excepted 74 12: just gentle sliding with your thumb will activate the opening spring KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
74 12 180 价格&库存
很抱歉,暂时无法提供与“74 12 180”相匹配的价格&库存,您可以联系我们找货
