77 52 115 ESD
77 52 115 ESD
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 成斜角 4.50"(114.3mm)
77 52 115 ESD 数据手册
77 52 115 ESD Electronics Diagonal Cutter ESD ● ● ● ● ● ● ● ● ● ● For fine cutting work, e.g. in electronics and fine mechanics Electrically discharging handles - dissipative Sturdy, zero-backlash box joint Low-friction double spring for gentle and even opening The mirror polish together with a fine film of oil offer effective rust protection - no circuit faults caused by peeling chrome from plated tools Cutting edges additionally induction hardened With two-colour dual component grips, black/grey High-grade special tool steel, forged, multi stage oil-hardened Pointed, flat head, with small bevel Cutting edge hardness approx. 60 HRC ESD pliers (electrostatic discharge) electrostatic energy is discharged through the handles in a gradual and controlled manner which protects components endangered by electrostatic discharge in accordance with applicable standards, e.g. IEC TR 61 340-5, DIN EN 61 340-5, SP Method 2472 Article No. 77 52 115 ESD EAN 4003773025139 Head mirror polished Handles with multi-component grips Style 5 Cutting capacities medium hard wire (diameter) Ø mm 0,8 Cutting capacities hard 0,5 wire (diameter) Ø mm Cutting capacities soft wire (diameter) Ø mm 0,3 - 1,0 B mm 13,0 D mm 7,0 A mm 11 Length mm 115 Net weight g 79 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
77 52 115 ESD 价格&库存
很抱歉,暂时无法提供与“77 52 115 ESD”相匹配的价格&库存,您可以联系我们找货
