79 02 125
79 02 125
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 成斜角 5.00"(127.0mm)
79 02 125 数据手册
79 02 125 Precision Electronics Diagonal Cutter ● ● ● ● ● ● ● ● ● Precision pliers for ultra fine cutting work, e. g. in electronics and fine mechanics Very precisely ground and sharp cutting edges with very small bevels for exact cutting on delicate electronic components; also available without bevel for flush cutting Cutting edges additionally induction hardened, cutting edge hardness approx. 64 HRC Approx. 20% lighter than conventional electronics pliers Bolted joint with carefully manufactured joint surfaces for even, lowfriction movement throughout the entire opening range Smooth-running double spring for a gentle and even opening Ergonomically optimised multi-component handles Ball bearing chrome steel, forged, multi stage oil-hardened Round head The subtle difference KNIPEX precision electronics pliers are made of high-quality ball bearing steel and processed with the highest degree of care. Each opening movement is gentle and even without backlash. Each work step proceeds reliably and precisely. This makes work much easier for professionals. Article No. 79 02 125 EAN 4003773061281 Pliers burnished Head polished Handles with multi-component grips Style 0 Cutting capacities medium hard wire (diameter) Ø mm 1,3 Cutting capacities hard 0,7 wire (diameter) Ø mm Cutting capacities soft wire (diameter) Ø mm 0,2 - 1,7 B mm 10 D mm 6,5 A mm 11 Nominal size 125 mm Length mm 125 Net weight g 59 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
79 02 125 价格&库存
很抱歉,暂时无法提供与“79 02 125”相匹配的价格&库存,您可以联系我们找货
