95 12 165 T
95 12 165 T
    KNIPEX(凯尼派克)
    KNIPEX - 95 12 165 T - Cable Cutter, 15mm Capacity, Dual-Component Grips, 165mm Length - Cable Cutte...
95 12 165 T 数据手册
95 12 165 T Cable Shears with tether attachment point ● ● ● ● ● ● ● ● ● Article No. 95 12 165 T EAN 4003773080190 Tool burnished Handles with multi-component grips, with integrated tether attachment point for a tool tether Style 1 Cutting capacity copper cable, multiple15 stranded (diameter) Ø mm For cutting copper and aluminium single conductors as well as multiple stranded cables Clean and smooth cut without crushing and deformation Not suitable for steel wire and hard drawn copper conductors Precision ground, hardened blades Easy cutting with one-hand operation With guard Adjustable bolted joint, self-retaining screw High-grade special tool steel, forged, oil-hardened Pliers with tether attachment point for mounting a fall protection Cut performed with a Diagonal Cutter: high effort required, inaccurate cut, considerable deforming and crushing of the cable Cut performed with a Cable Shear: easy, clean cut without any deformation of the cable Cutting capacity copper cable, multiple- 50 stranded mm² AWG 1/0 Length mm 165 Net weight g 255 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 12 165 T 价格&库存
很抱歉,暂时无法提供与“95 12 165 T”相匹配的价格&库存,您可以联系我们找货
