95 16 165 T
95 16 165 T
    KNIPEX(凯尼派克)
    缆线 切割器 椭圆形 剪 6.50"(165.1mm)
95 16 165 T 数据手册
95 16 165 T Cable Shears with tether attachment point ● ● ● ● ● ● ● ● ● Article No. 95 16 165 T EAN 4003773081524 Tool chrome plated Handles insulated with multicomponent grips, VDEtested with integrated insulated tether attachment point for a tool tether Style 1 Insulation standard IEC 60900 DIN EN 60900 Cutting capacity copper cable, multiple15 stranded (diameter) Ø mm For cutting copper and aluminium single conductors as well as multiple stranded cables Not suitable for steel wire and hard drawn copper conductors Precision ground, hardened blades Clean and smooth cut without crushing and deformation Easy cutting with one-hand operation Guard prevents operators’ fingers being pinched Adjustable bolted joint, self-retaining screw High-grade special tool steel, forged, oil-hardened With integrated insulated tether attachment point for a tool tether Cut performed with a Diagonal Cutter: high effort required, inaccurate cut, considerable deforming and crushing of the cable Cut performed with a Cable Shear: easy, clean cut without any deformation of the cable Cutting capacity copper cable, multiple- 50 stranded mm² AWG 1/0 Length mm 165 Net weight g 256 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 16 165 T 价格&库存
很抱歉,暂时无法提供与“95 16 165 T”相匹配的价格&库存,您可以联系我们找货
