00 21 20 LE
00 21 20 LE
    KNIPEX(凯尼派克)
    KNIPEX - 00 21 20 LE - Tool Case, ABS, Flip Lock, 15 Compartment, 370 mm x 480 mm x 175 mm
00 21 20 LE 数据手册
00 21 20 LE Tool Case "Standard" empty ● ● ● ● ● ● ● ● ● ● Article No. 00 21 20 LE EAN 4003773044567 Dimension exterior (interior) width mm mm 480 (460) Dimension exterior (interior) height mm mm 175 (170) Dimension exterior (interior) depth mm mm 370 (310) Net weight g 4485 Heavy duty ABS material, black With circumferential double aluminium frame Register hinges working as lid holder Strong, ergonomic handle Two flip-locks, lockable One removable tool board in the lid with 15 push-in compartments on the bottom side and six big push-in compartments and a clamp compartment (400 mm width) on the lid side, fixed by push-button Base tray, height 58 mm, can be subdivided by flexible inserts; cover plate with six large push-in compartments, can be fixed by press button Cover and tool plate made of Con-Pearl® material 20 kg maximum load Without tools technical change and errors excepted Con-Pearl® is a registered trade mark of friedola TECH GmbH KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
00 21 20 LE 价格&库存
很抱歉,暂时无法提供与“00 21 20 LE”相匹配的价格&库存,您可以联系我们找货
