70 06 125
Diagonal Cutter
Article No.
70 06 125
EAN
4003773018124
Pliers
chrome plated
Handles
insulated with multicomponent grips, VDEtested
Style
Head
Insulation standard
IEC 60900 DIN EN 60900
Cutting capacities
medium hard wire
(diameter) Ø mm
2,3
The indispensable diagonal cutter for all-round use
High-quality material and precise workmanship for long service life
Precision cutting edges for soft and hard wire
Clean cutting of thin copper wires, also at the cutting-edge tips
Cutting edges additionally induction hardened, cutting edge hardness
approx. 62 HRC
Narrow head style for use in confined areas
Vanadium electric steel, forged, multi stage oil-hardened
Slim head style and
precise cut at blade
tips: Advantageous
when working in
confined areas
Cutting capacities hard
1,5
wire (diameter) Ø mm
Cutting capacities soft
3,0
Nominal size
125 mm
Length mm
125
Net weight g
121
technical change and errors excepted
KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany
info@knipex.de | www.knipex.de
1
很抱歉,暂时无法提供与“70 06 125”相匹配的价格&库存,您可以联系我们找货
