75 02 125
75 02 125
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 成斜角 5.00"(127.0mm)
75 02 125 数据手册
75 02 125 Electronics Diagonal Cutter ● ● ● ● ● ● Bolted joint for high precision and stress tolerance For ultra fine cutting work, e.g. in electronics and fine mechanics With sharp, ground cutting edges for soft and hard wire and piano wire Cutting edges additionally induction hardened, cutting edge hardness approx. 64 HRC Low-friction double spring for gentle and even opening High-grade special tool steel, forged, multi stage oil-hardened Style:with bevel ❍ Article No. 75 02 125 EAN 4003773040491 Pliers burnished Handles with plastic grips Style 0 Cutting capacities medium hard wire (diameter) Ø mm 1,0 Bolted joint Cutting capacities hard 0,6 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 0,4 Cutting capacities soft wire (diameter) Ø mm 0,2 - 1,3 B mm 14 D mm 6,5 A mm 10,5 Length mm 125 Net weight g 81 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
75 02 125 价格&库存
很抱歉,暂时无法提供与“75 02 125”相匹配的价格&库存,您可以联系我们找货
