77 01 115
77 01 115
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 成斜角 4.50"(114.3mm)
77 01 115 数据手册
Electronics Diagonal Cutters DIN ISO 9654 77 01 115 head mirror polished, handles plastic coated, round head 77 02 115 head mirror polished, handles with multi-component grips, round head 77 02 130 head mirror polished, handles with multi-component grips, round head 77 11 115 head mirror polished, handles plastic coated, round head 77 72 115 head mirror polished, handles with multi-component grips, round head 77 21 130 head mirror polished, handles plastic coated, pointed head 77 21 115 N head mirror polished, handles with plastic grips 77 22 115 head mirror polished, handles with multi-component grips, round head 77 22 130 head mirror polished, handles with multi-component grips, round head 77 32 115 head mirror polished, handles with multi-component grips, pointed head 77 41 115 head polished, handles with non-slip plastic covers, pointed head 77 42 115 head mirror polished, handles with multi-component grips, pointed head 77 52 115 head mirror polished, handles with multi-component grips, pointed, flat head 77 72 115 head mirror polished, handles with multi-component grips, pointed mini-head Description Applications Technical design Videos For fine cutting work, e.g. in electronics and fine mechanics Load-optimised for a more direct feel when working Sturdy, zero-backlash box joint Low-friction double spring for gentle and even opening The polish or mirror polish (only finish 2) together with a fine film of oil offer effective rust protection - no circuit faults caused by peeling chrome from plated tools Cutters additionally laser hardened, cutter hardness at least 60 HRC Narrow sleeves pulled up to the head of the pliers enable the tool to be guided securely and comfortably, also between thumb and index finger Ball bearing chrome steel Model 77 01 115 : Round head, with bevel Cutting edge hardness approx. 62 HRC Model 77 01 130 : Round head, with bevel Cutting edge hardness approx. 62 HRC Model 77 02 115 : Round head, with small bevel Cutting edge hardness approx. 60 HRC Model 77 02 130 : Round head, with bevel Cutting edge hardness approx. 62 HRC Model 77 11 115 : Round head, with bevel and lead catcher - no uncontrolled loss of cut wire ends Cutting edge hardness approx. 62 HRC Model 77 12 115 : Round head, with bevel and lead catcher - no uncontrolled loss of cut wire ends Cutting edge hardness approx. 62 HRC Model 77 21 130 : Round head, without bevel Cutting edge hardness approx. 57 HRC Model 77 21 115 N : Round head, without bevel Model 77 22 115 : Round head, without bevel Cutting edge hardness approx. 57 HRC Model 77 22 130 : Round head, with small bevel Cutting edge hardness approx. 60 HRC Model 77 32 115 : Pointed head, with small bevel Cutting edge hardness approx. 60 HRC Model 77 42 115 : Pointed head, without bevel Cutting edge hardness approx. 57 HRC Model 77 42 130 : Pointed head, without bevel Cutting edge hardness approx. 57 HRC Model 77 52 115 : Pointed, flat head, with small bevel Cutting edge hardness approx. 60 HRC Model 77 72 115 : Pointed mini-head, with small bevel Cutting edge hardness approx. 60 HRC Article No. EAN 4003773- Ø mm Ø mm Ø mm B mm A mm D mm mm g 77 01 115 018568 0,3 1,6 1,20 0,60 13,00 11,00 7,00 115 67 77 01 130 018575 0,3 2,0 1,50 0,80 18,00 15,00 9,50 130 108 77 02 115 039334 0,3 1,6 1,20 0,60 13,00 11,00 7,00 115 80 77 02 130 039341 0,3 2,0 1,50 0,80 18,00 15,00 9,50 130 124 77 11 115 018629 0,3 1,6 1,20 0,60 13,00 11,00 7,50 115 70 77 12 115 043768 0,3 1,6 1,20 0,60 13,00 11,00 7,00 115 80 77 21 130 018667 0,3 1,6 1,30 18,00 14,00 9,50 130 110 77 21 115 N 082309 1,3 1,00 13,00 11,00 7,00 115 50 77 22 115 043782 0,3 1,3 1,00 13,00 11,00 7,00 115 80 77 22 130 040446 0,3 2,0 1,50 18,00 15,00 9,00 130 124 77 32 115 044307 0,3 1,3 1,00 0,50 13,00 11,00 7,00 115 80 77 41 115 082316 1,3 0,80 13,00 11,00 7,00 115 50 77 42 115 039761 0,3 1,3 0,80 13,00 11,00 7,00 115 80 77 42 130 018773 0,3 1,6 1,30 18,00 15,00 9,50 130 122 77 52 115 040750 0,3 1,0 0,80 0,50 13,00 11,00 7,00 115 77 77 72 115 040958 0,3 0,8 12,00 11,00 7,00 115 69 For explanation of the wire classes technical change and errors excepted
77 01 115 价格&库存
很抱歉,暂时无法提供与“77 01 115”相匹配的价格&库存,您可以联系我们找货
