78 06 125
78 06 125
    KNIPEX(凯尼派克)
    KNIPEX - 78 06 125 - Cutter, Electronic, 125 mm, Shear, 9 mm, 54 °
78 06 125 数据手册
Product information 78 06 125 ● VDE-tested precision pliers for ultra fine cutting work, e.g. in electronics and fine mechanics ● Complete your set of VDE-tools ● Ground, very sharp cutting edges without bevel ● Shear cut with controlled micro cutting edge misalignment for the most precise cutting of even the thinnest of wires and for a long service life ● Precision shaped tips cut wires flush to a surface from Ø 0.2 mm. ● Joint with stainless steel rivet ● Extremely smooth movement for minimum operator fatigue ● With opening spring and opening limiter ● Cutting edge hardness approx. 54 HRC Electronic Super Knips® VDE DIN ISO 9654 IEC 60900 DIN EN 60900 General Article No. 78 06 125 EAN 4003773084099 Head polished Handles insulated with multi-component grips, VDE-tested weight 75 g Dimensions 125 x 65 x 13 mm Standard DIN ISO 9654 DIN EN 60900 IEC 60900 Technische Attribute Cutting capacities medium hard wire (diameter) Ø 1.0 mm Cutting capacities soft wire (diameter) Ø 0.2 – 1.6 mm 9 mm 7.5 mm Head width 13.5 mm Classification eCl@ss 5.1.4 21040302 ETIM 5.0 EC000165 ETIM 6.0 EC000165 proficl@ss 6.0 AAA949c004 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 1 3 !Für Einsätze unter Spannung bis 1000 V! KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 2 3 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 3 3
78 06 125 价格&库存
很抱歉,暂时无法提供与“78 06 125”相匹配的价格&库存,您可以联系我们找货
