78 61 125 ESD
78 61 125 ESD
    KNIPEX(凯尼派克)
78 61 125 ESD 数据手册
78 61 125 ESD Electronic Super Knips® ESD ● ● ● ● ● ● ● ● ● ● Precision pliers for ultra fine cutting work, e. g. in electronics and fine mechanics Electrically discharging handles - dissipative Ground, very sharp cutting edges without bevel Shear cut with controlled micro cutting edge misalignment for the most precise cutting of even the thinnest of wires and for a long service life Precision shaped tips cut wires resting on a board from 0.2 mm dia. Joint with stainless steel rivet Extremely smooth movement for minimum operator fatigue With opening spring and opening limiter Cutting edges additionally induction hardened, cutting edge hardness approx. 64 HRC Special tool steel, burnished ESD pliers (electrostatic discharge) electrostatic energy is discharged through the handles in a gradual and controlled manner which protects components endangered by electrostatic discharge in accordance with applicable standards, e.g. IEC TR 61 340-5, DIN EN 61 340-5, SP Method 2472 Article No. 78 61 125 ESD EAN 4003773025184 Pliers burnished Handles with multi-component grips Style 6 Head Cutting capacities medium hard wire (diameter) Ø mm 1,2 Cutting capacities soft wire (diameter) Ø mm 0,2 - 1,6 D mm 7,5 B mm 9,0 A mm 13,5 Length mm 125 Net weight g 56 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
78 61 125 ESD 价格&库存
很抱歉,暂时无法提供与“78 61 125 ESD”相匹配的价格&库存,您可以联系我们找货
