78 61 140 ESD
78 61 140 ESD
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 凹槽 5.50"(139.7mm)
78 61 140 ESD 数据手册
78 61 140 ESD Electronic Super Knips® XL ESD ● ● ● ● ● ● ● ● ● ● For ultra fine cutting work, e.g. in electronics and fine mechanics Ground, very sharp cutting edges without bevel Shear cut with controlled micro cutting edge misalignment for the most precise cutting of even the thinnest of wires and for a long service life Precision shaped tips cut wires resting on a board from 0.2 mm dia. Joint with stainless steel rivet Extremely smooth movement for minimum operator fatigue With opening spring and opening limiter Cutting-edge hardness approx. 64 HRC Cutting edges additionally induction hardened Special tool steel, oil hardened in multiple stages ESD pliers (electrostatic discharge) electrostatic energy is discharged through the handles in a gradual and controlled manner which protects components endangered by electrostatic discharge in accordance with applicable standards, e.g. IEC TR 61 340-5, DIN EN 61 340-5, SP Method 2472 Article No. 78 61 140 ESD EAN 4003773081708 Pliers burnished Head Handles with multi-component grips Cutting capacities medium hard wire (diameter) Ø mm 1,4 Cutting capacities soft wire (diameter) Ø mm 0,2 - 2,1 B mm 12,3 D mm 9,2 A mm 15,7 Length mm 140 Net weight g 77 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
78 61 140 ESD 价格&库存
很抱歉,暂时无法提供与“78 61 140 ESD”相匹配的价格&库存,您可以联系我们找货
