95 06 230
95 06 230
    KNIPEX(凯尼派克)
    缆线 切割器 圆形 剪 9.25"(235.0mm)
95 06 230 数据手册
95 06 230 Cable Shears ● ● ● ● ● ● ● ● ● ● ● Article No. 95 06 230 EAN 4003773006305 Head polished Handles plastic insulated, VDEtested Insulation standard IEC 60900 DIN EN 60900 For cutting copper and aluminium cables Not suitable for steel wire and hard drawn copper conductors Precision ground, hardened blades No crushing, slight deformation of the cable only With guard Adjustable bolted joint Shears body: surgical steel, stainless, vacuum-hardened Handles: plastic, impact-proof For copper single conductors up to 16 mm², multiple stranded wires up to 50 mm², fine stranded up to 70 mm² and aluminium conductors multiple stranded wires up to 70 mm² Easy cutting with one-hand operation due to high transmission ratio Stainless - special grade - steel, oil-hardened and tempered Cutting capacity copper cable, multiple16 stranded (diameter) Ø mm Cutting capacity copper cable, multiple- 50 stranded mm² AWG 1/0 Length mm 230 Net weight g 274 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 06 230 价格&库存
很抱歉,暂时无法提供与“95 06 230”相匹配的价格&库存,您可以联系我们找货
