95 12 200
95 12 200
    KNIPEX(凯尼派克)
    200mm Length Cable Shear with 70mm² Capacity
95 12 200 数据手册
95 12 200 Cable Shears with twin cutting edge ● ● ● ● ● ● ● ● ● For cutting copper and aluminium cables Not suitable for steel wire and hard drawn copper conductors Precision ground, hardened blades Clean and smooth cut without crushing and deformation By dividing the cutting actions into initial cut (insulating sheath in the front cutting area) and final cut (conductor in the back cutting area), cables up to Ø 20 mm can be cut in one-hand operation Less effort required due to favourable lever ratio and optimised cutting-edge geometry Guard prevents operators’ fingers being pinched Adjustable bolted joint, self-retaining screw High-grade special tool steel, forged, oil-hardened The twin cutting edge allows a comfortable handle position in all cutting situations within the specified cutting capacity. Article No. 95 12 200 EAN 4003773047834 Tool burnished Handles with multi-component grips Cutting capacity copper cable, multiple20 stranded (diameter) Ø mm Cutting capacity copper cable, multiple- 70 stranded mm² AWG 2/0 Length mm 200 Net weight g 324 Initial cut: using the front cutting edge to cut the insulating sheath on larger cable diameters leaves an ergonomic handle opening width. Final cut: after cutting the sheath in the front profile the conductors in the rear part are cut. Initial cut in the front profile, final cut in the rear profile - to keep it as easy as possible. technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 12 200 价格&库存
很抱歉,暂时无法提供与“95 12 200”相匹配的价格&库存,您可以联系我们找货
