95 32 060
95 32 060
    KNIPEX(凯尼派克)
    KNIPEX - 95 32 060 - Cable Cutter, 60mm Capacity, Telescopic Handle, 630mm Length
95 32 060 数据手册
95 32 060 Cable Cutter (ratchet action) with telescopic handles ● ● ● ● ● ● ● ● ● ● ● Article No. 95 32 060 EAN 4003773071563 Head burnished Handles with multi-component grips For copper and aluminium single conductors as well as multiple stranded cables - also with hard rubber or plastic sheath Not suitable for steel wire and wire ropes Also suitable for cables with iron sheath reinforcement Little hand force required for cutting due to optimum transmission ratio High cutting capacity due to two-hand operation and ratchet action The blade can be opened in any cutting position Handle length with multiple position adjustment from 400 - 610 mm (short transport length, individual adaptation to working conditions) Blade: special-quality high-grade tool steel, oil-hardened Handles: high-strength oval aluminium tubing Tool length: 600 - 810 mm Weight only approx. 3820 g Cutting capacity copper cable, multiple60 stranded (diameter) Ø mm Cutting capacity copper cable, multiple- 740 stranded mm² MCM 1400 Length mm 630 Net weight g 3820 technical change and errors excepted Spare Parts Article No. EAN 95 39 720 4003773025290 Movable spare blade for 95 31 720 / 95 32 060 (ratchet action) KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 32 060 价格&库存
很抱歉,暂时无法提供与“95 32 060”相匹配的价格&库存,您可以联系我们找货
