97 33 02
97 33 02
    KNIPEX(凯尼派克)
    KNIPEX - 97 33 02 - Crimp Tool, Hand, 20-10AWG Non-Insulated Open Plug Type Connectors
97 33 02 数据手册
97 33 02 KNIPEX MultiCrimp® crimping pliers with changer magazine and 5 crimping dies ● ● ● ● ● ● ● ● Just one tool for the most common crimping applications Crimping dies changed quickly and easily without any additional tool Sorted and protected storage of the interchangeable dies in a round magazine Comfortable, powerful crimping pliers in professional quality Same reliable crimping results as with fixed crimping dies Repetitive, high crimping quality due to precision dies and integral lock (self-releasing mechanism) Chrome vanadium electric steel in special quality, oil-hardened Round magazine: plastic, fibreglass-reinforced Compact, inexpensive and light-weight crimping pliers for fitting and repairs. The electrician needs only one tool now instead of five as before. Article No. 97 33 02 EAN 4003773066934 Pliers burnished Handles with multi-component grips Applications non-insulated open plug type connectors (plug width 4.8 + 6.3 mm) Capacity in square millimetres mm² 0,5 - 6,0 Number of crimping positions 3 AWG 20 - 10 Length mm 250 Net weight g 870 technical change and errors excepted Changing position: service lever opens out for parallel jaw positioning Changing the crimping dies: unlock the magazine position, take out the set of dies which the pliers have been pushed on Fold in the service lever and press the pliers – ready for use again Magazine for crimping dies can be carried on a belt Clearly visible marking on the crimping dies with pictograms Accessories Article No. EAN 97 39 05 4003773070078 Crimping dies for non-insulated open plug type connectors (plug width 4.8 + 6.3 mm) 97 39 06 4003773070085 Crimping dies for insulated terminals, plug connectors and butt connectors 97 39 08 4003773070092 Crimping dies for insulated and non-insulated end sleeves (ferrules) 97 39 09 4003773077763 Crimping dies for insulated and non-insulated end sleeves (ferrules) KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 97 39 13 4003773070108 Crimping dies for non-insulated crimp terminals, tube and compression cable lugs in accordance with DIN 46234 and DIN 46235 and non-insulated crimp, butt and press connectors in accordance with DIN 46341 and DIN 46267 97 39 30 4003773070115 Crimping dies for compression joints according to DIN 46267 97 39 90 4003773070061 Changer Magazine empty KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
97 33 02
1. 物料型号:973302,EAN号为4003773066934。 2. 器件简介:KNIPEX MultiCrimp®压接钳配有可更换的压接模具和5种压接模具,这些模具可以快速、轻松地更换,无需额外工具。工具具有专业质量,铬钒合金材质,油淬火处理,具有自锁机制,保证重复、高质量的压接。 3. 引脚分配:适用于非绝缘开放式插头型连接器(插头宽度4.8 + 6.3毫米),容量范围0.5-6.0平方毫米,3个压接位置,AWG线规20-10,长度250毫米,净重870克。 4. 参数特性:压接钳的手柄采用多组分握把,压接位置更换通过服务杆平行夹持位调整,服务杆内压接模具更换,取下并重新装上模具组。 5. 功能详解:压接模具的存储在圆形塑料、玻璃纤维增强的杂志中,可以系在腰带上,压接模具上有明显的带有图示的标记。 6. 应用信息:适用于电工安装和维修,压接钳轻巧、经济、便携,一个工具代替了以前需要的五个工具。 7. 封装信息:KNIPEX-Werk C. Gustav Putsch KG, Oberkamper Straße 13, 42349 Wuppertal, Germany,提供多种压接模具的配件信息。
97 33 02 价格&库存
很抱歉,暂时无法提供与“97 33 02”相匹配的价格&库存,您可以联系我们找货
