97 43 200
97 43 200
    KNIPEX(凯尼派克)
    手动压接器 工具 因模具套件而异
97 43 200 数据手册
97 43 200 Crimp System Pliers for exchangeable crimping dies ● ● ● ● ● ● ● ● ● ● ● Just one tool for almost 1000 crimping applications Almost parallel crimping die movement Repetitive, high crimping quality due to precision dies and integral lock (self-releasing mechanism) Crimping pressure has been set precisely (calibrated) in the factory, re-adjustable Optimum transmission of force due to lever action for fatigue-reduced operation Ergonomically designed handles Different locators for precise positioning of the connectors Crimping dies for applications not covered in the range offered here, may be available on request Chrome vanadium electric steel in special quality, oil-hardened Comes in a plastic case; foam insert with recesses for crimping dies and locators; with service tool (Allen key), screws and nuts Without crimping dies With the possibility of crimping almost all currently available crimping connections with just one tool and state-of-the-art crimping pliers technology, the crimp system pliers solves almost all tasks in mobile and stationary crimping technology and is an excellent tool for professionals to use for standard crimping. Article No. 97 43 200 EAN 4003773030812 Pliers burnished Handles with multi-component grips Applications see crimping dies table Length mm 200 Net weight g 988 97 43 200 with crimping dies 97 49 06 for insulated terminals, plug connectors and butt connectors 97 43 200 with crimping dies 97 49 09 for end sleeves (ferrules) 97 43 400 with crimping dies 97 49 24 and locator 97 49 93 for D-Sub plugs technical change and errors excepted Spare Parts Article No. EAN 97 49 200 01 4003773053927 Spring for 97 43 Accessories Article No. EAN 97 49 04 4003773030850 Crimping dies for non-insulated open plug-type connectors 2.8 + 4.8 mm 97 49 05 4003773030867 Crimping dies for non-insulated open plug-type connectors 4.8 + 6.3 mm 97 49 06 4003773030836 Crimping dies for insulated terminals + plug connectors KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 97 49 08 4003773030874 Crimping dies for insulated and non-insulated end sleeves (ferrules) 97 49 09 4003773030881 Crimping dies for end sleeves (ferrules) 97 49 10 4003773076896 Crimping dies for non-insulated tubular cable lugs and crimp terminals in accordance with DIN 46237 and non-insulated butt and crimp connectors in accordance with DIN 46341 97 49 11 4003773076902 Crimping dies for non-insulated crimp terminals, tube and compression cable lugs in accordance with DIN 46234 and DIN 46235 and non-insulated crimp, butt and press connectors in accordance with DIN 46341 and DIN 46267 97 49 13 4003773030843 Crimping dies for non-insulated crimp terminals, tube and compression cable lugs in accordance with DIN 46234 and DIN 46235 and non-insulated crimp, butt and press connectors in accordance with DIN 46341 and DIN 46267 97 49 14 4003773077756 Crimping dies for non-insulated crimp terminals, tube and compression cable lugs in accordance with DIN 46234 and DIN 46235 and non-insulated crimp, butt and press connectors in accordance with DIN 46341 and DIN 46267 97 49 15 4003773043164 Crimping dies for lug connectors and non-insulated open plug-type connectors 4.8 + 6.3 mm 97 49 16 4003773040675 Crimping dies for insulated terminals + plug connectors 97 49 18 4003773063186 Crimping dies for twin end sleeves 97 49 19 4003773030898 Crimping dies for end sleeves (ferrules) 97 49 20 4003773045069 Crimping dies for F-connectors for TV and satellite connections 97 49 23 4003773052135 Crimping dies for non-insulated terminals + cable connectors 97 49 24 4003773030911 Crimping dies for D-Sub-plugs 97 49 30 4003773030904 Crimping dies for non-insulated butt connectors 97 49 35 4003773034315 Crimping dies for spark plug connectors and distributors 97 49 40 4003773030959 Crimping dies for Coax connectors 97 49 44 4003773041443 Crimping dies for rolled contacts 97 49 50 4003773030966 Crimping dies for Coax connectors / car phone 97 49 54 4003773041450 Crimping dies for modular plugs 97 49 60 4003773030928 Crimping dies for turned contacts (HTS + Harting) 97 49 61 4003773045137 Crimping dies for turned contacts (Harting) 97 49 62 4003773063179 Crimping dies for solar cable connectors (Huber + Suhner) 97 49 63 4003773066675 Crimping dies for solar cable connectors (Huber + Suhner) 97 49 64 4003773044055 Crimping dies for ABS connectors 97 49 65 4003773066682 Crimping dies for solar cable connectors MC3 (Multi-Contact) 97 49 65 1 4003773066729 Locator for 97 49 65 (solar cable connectors MC3) 97 49 66 4003773066699 Crimping dies for solar cable connectors MC4 (Multi-Contact) 97 49 66 1 4003773066736 Locator for 97 49 66 (solar cable connectors MC4) 97 49 67 4003773066705 Crimping dies for solar cable connectors SunCon (Hirschmann) 97 49 68 4003773066712 Crimping dies for turned solar cable connectors (Tyco) 97 49 68 1 4003773066743 Locator for 97 49 68 (solar cable connectors Solarlok) 97 49 70 4003773030942 Crimping dies for Western plugs 97 49 71 4003773075066 Crimping dies for solar cable connectors MC4 (Multi-Contact) 97 49 74 4003773044062 Crimping dies for unshielded Molex plugs 97 49 76 4003773047513 Crimping dies for shielded Stewart plugs 97 49 81 4003773042778 Crimping dies for Harting connectors for fibre optics 97 49 82 4003773042785 Crimping dies for Telegärtner connectors for fibre optics 97 49 83 4003773044079 Crimping dies for FSMA, ST, SC, STSC/K connectors 97 49 84 4003773042792 Crimping dies for Harting/Suhner conncectors for fibre optics 97 49 87 4003773043331 Crimping dies for FSMA, ST and MIC connectors for fibre optics 97 49 90 4003773031017 Locator for 97 49 60 (HTS+Harting) 97 49 91 4003773045144 Locator for 97 49 61 (Harting) 97 49 93 4003773047926 Locator for 97 49 24 (D-Sub-plugs) 97 49 94 4003773030997 Locator for 97 49 04 97 49 95 4003773031000 Locator for 97 49 05 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
97 43 200 价格&库存
很抱歉,暂时无法提供与“97 43 200”相匹配的价格&库存,您可以联系我们找货
