98 24 00
98 24 00
    KNIPEX(凯尼派克)
    KNIPEX - 98 24 00 - Phillips Screwdriver, VDE, #0 Tip, 60 mm Blade Length, 162 mm Overall Length
98 24 00 数据手册
98 24 00 Screwdriver for cross recessed screws Phillips® ● ● ● Article No. 98 24 00 EAN 4003773026433 Tip burnished Handle insulating multicomponent handle, VDEtested Insulation standard IEC 60900 DIN EN 60900 Size PH 0 Blade length mm 60 Handle length mm 102 Blade dia. mm 3 Nominal size PH0 Length of noninsulated blade mm 15 Length mm 162 Net weight g 32 Ergonomically optimised dual component handle for fatigue reduced work and optimum transmission of force Handle design prevents rolling Chrome vanadium molybdenum steel technical change and errors excepted Phillips® is a registered trademark of Phillips Screw Company KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
98 24 00 价格&库存
很抱歉,暂时无法提供与“98 24 00”相匹配的价格&库存,您可以联系我们找货
