Double-Edged Screw Extractors
from Rennsteig
Patent
Pending
Product Specification
• f or unscrewing damaged screws
and bolts without damaging threads
• for both right and left handed threads
• non-slip and double-edged engagement with the
screw being removed
The Double-Edged Screw Extractor represents a new
generation of its kind used to remove damaged screws or
bolts out of threads.
Centering point
for centering of bore
Cutting edges
for non-slip engagement
The Screw Extractors have four double-edged cutting
edges. Only the two opposite edges engage with the
screw to be removed.
This technology is perfect for use with both right and left
handed threads.
Application
the screw / bolt to be removed by using the
• mark
centering point of the Screw Extractor
the screw / bolt by boring with an adequate drill
• open
• drive the Screw Extractor into the bore hole until the
cutting edges are in full contact with the object
Hexagonal driving flat
for optimum torque
a wrench to remove the object out of the thread
• use
hole by turning the screw extractor clockwise or
counterclockwise
unscrewing, remove the damaged screw / bolt
• after
from the Screw Extractor
RENNSTEIG
Rennsteig is a division of the KNIPEX Group that
specializes in the manufacturing and development of
high quality tools. For over 30 years, Rennsteig has
been manufacturing products designed for maximum
performance, ease of use and long life.
2035 S. Arlington Heights Rd., Suite 110, Arlington Heights, IL 60005 | 847.398.8520 • 847.398.8526 (fax) | www.knipex-tools.com
KNIPEX Quality – Made in Germany
from Rennsteig
Range of Delivery
The Double-Edged Screw Extractor is available
in 7 different sizes!
sw
Art.-No.
Drill Ø mm
Screw Sizes
sw
Drill Ø Inch
Screw Sizes Inch
Size
mm
min
max
min
max
Inch
min
max
min
max
ounces
9R 471 001 3
1
6.3
3.2
4.8
M5
M6
1/4”
1/8”
3/16”
10”
1/4“
0.3
10
9R 471 002 3
2
10
4.8
7.1
M8
M10
3/8”
1/4”
9/32”
5/16”
3/8”
0.6
10
9R 471 003 3
3
13
6.4
9.5
M10
M12
1/2”
1/4”
3/8”
7/16”
1/2”
1.2
10
9R 471 004 3
4
16
8.7
12.7
M12
M16
5/8”
11/32”
1/2”
1/2”
9/16”
2.0
10
9R 471 005 3
5
19
11.1
15.9
M16
M20
3/6”
7/16”
5/8”
5/8”
3/4”
3.1
10
9R 471 006 3
6
22
14.3
19.1
M20
M24
7/8”
9/16”
3/4”
7/8”
1”
4.6
5
9R 471 007 3
7
26
19.1
23.8
M30
1”
3/4”
15/16”
1”
>1”
7.2
5
Packaging Options
Individual Item in
Transparent Plastic Case
Size 1-5 in Vinyl Pouch
Art.-No. 9R 471 900 3
Size 1-5 in Metal Case
很抱歉,暂时无法提供与“9R 471 901 3”相匹配的价格&库存,您可以联系我们找货
