13 46 165
13 46 165
    KNIPEX(凯尼派克)
    KNIPEX - 13 46 165 - Plier, Dismantling, 165 mm Length - Plier, Dismantling, 165 mm Length
13 46 165 数据手册
13 46 165 Stripping Pliers ● ● ● ● ● ● ● ● Article No. 13 46 165 EAN 4003773079699 For time-saving stripping of all round sheathed and damp-proof installation cables (e.g. NYM cable) Simplified access especially into deep mounted junction boxes thanks to slim head design and optimally angled cable sheath cutter Strip cables easily and without damage thanks to circular cutting edge with depth limiter Suitable for universal use: precision wire stripping holes for conductors from 1.5 and 2.5 mm² With side cutters for cutting and trimming conductors, wires, small screws and nails All cutters additionally induction hardened to approx. 61 HRC for high wear resistance 30 % lighter than comparable pliers Vanadium electric steel, forged, multi stage oil-hardened Head Pliers chrome plated Handles insulated with multicomponent grips, VDEtested Cutting capacities medium hard wire (diameter) Ø mm 3,2 Cutting capacities hard 2,2 wire (diameter) Ø mm Cable stripping values (diameter) Ø mm 8 - 13 Stripping capacities in square millimetres mm² 0,75 - 1,5 / 2,5 Length mm 165 Net weight g 190 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
13 46 165
- 物料型号: KNIPEX 1346 165 - 器件简介: 铬镀钳子,具有绝缘手柄和VDE测试,适用于1000V电压。 - 引脚分配: 无引脚分配信息,因为这是一个工具而非电子元件。 - 参数特性: 适用于切割直径为3.2mm的中等硬度电线和2.2mm的硬电线;剥线范围为直径8-13mm的电缆,剥线容量为0.75-1.5/2.5mm²。 - 功能详解: 特别设计用于节省时间地剥离所有圆形护套和防潮G安装电缆;由于头部设计紧凑,可以简化进入深装接线盒的访问;圆形切割刃带有深度限制器,可以轻松无损地剥离电缆;适用于通用用途,具有用于1.5和2.5mm²导体的精密剥线孔;带有侧切刀,用于切割和修整导体、电线、小螺丝和钉子。 - 应用信息: 适用于各种剥线和切割任务,特别是在电气安装和维修工作中。
13 46 165 价格&库存
很抱歉,暂时无法提供与“13 46 165”相匹配的价格&库存,您可以联系我们找货
