34 12 130
34 12 130
    KNIPEX(凯尼派克)
    电子设备 钳子 平头 平滑 5.25"(133.4mm)
34 12 130 数据手册
34 12 130 Precision Electronics Gripping Pliers ● ● ● ● ● ● ● ● For very precise assembly work, e.g. in electronics and fine mechanics For gripping, holding and bending Smoothly ground gripping surfaces, edges finely rounded Approx. 20% lighter than conventional electronics pliers Bolted joint and carefully manufactured joint surfaces for even, lowfriction movement throughout the entire opening range Smooth-running double spring for a gentle and even opening Ergonomically optimised multi-component handles Ball bearing chrome steel, forged, multi stage oil-hardened Style:flat, wide jaws ❍ The subtle difference KNIPEX precision electronics pliers are made of high-quality ball bearing steel and processed with the highest degree of care. Each opening movement is gentle and even without backlash. Each work step proceeds reliably and precisely. This makes work much easier for professionals. Article No. 34 12 130 EAN 4003773061458 Pliers burnished Head polished Handles with multi-component grips Style 1 B mm 21,9 D mm 6,5 E mm 1,4 F mm 3,5 A mm 11,2 Nominal size 130 mm Length mm 135 Net weight g 61 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
34 12 130 价格&库存
很抱歉,暂时无法提供与“34 12 130”相匹配的价格&库存,您可以联系我们找货
