34 52 130 ESD
Precision Electronics Gripping Pliers ESD
For very precise assembly work, e.g. in electronics and fine
mechanics
For gripping, holding and bending
Electrically discharging handles - dissipative
Smoothly ground gripping surfaces, edges finely rounded
Approx. 20% lighter than conventional electronics pliers
Bolted joint and carefully manufactured joint surfaces for even, lowfriction movement throughout the entire opening range
Smooth-running double spring for a gentle and even opening
Ergonomically optimised multi-component handles
Ball bearing chrome steel, forged, multi stage oil-hardened
Style:half-round jaws
Style:with precision laser cut cross-shaping
The subtle difference
KNIPEX precision electronics pliers are made of high-quality ball bearing steel and processed with the highest degree of care. Each opening
movement is gentle and even without backlash. Each work step proceeds reliably and precisely. This makes work much easier for professionals.
ESD pliers (electrostatic discharge)
electrostatic energy is discharged through the handles in a gradual and controlled manner
which protects components endangered by electrostatic discharge
in accordance with applicable standards, e.g. IEC TR 61 340-5, DIN EN 61 340-5, SP Method 2472
Article No.
34 52 130 ESD
EAN
4003773080305
Style
5
Pliers
burnished
Head
polished
Handles
with multi-component
grips
B mm
22,70
D mm
6,50
E mm
1,60
F mm
1,60
A mm
11,20
Length mm
130
Net weight g
61
technical change and errors excepted
KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany
info@knipex.de | www.knipex.de
1
很抱歉,暂时无法提供与“34 52 130 ESD”相匹配的价格&库存,您可以联系我们找货
