35 12 115 ESD
35 12 115 ESD
    KNIPEX(凯尼派克)
    电子设备 钳子 平头 平滑 4.50"(114.3mm)
35 12 115 ESD 数据手册
35 12 115 ESD Electronics Pliers ESD ● ● ● ● ● ● ● ● ● ● ● ● Precision pliers for fine assembly work, e g. in electronics and fine mechanics Load-optimised for a more direct feel when working For gripping, holding and bending Electrically discharging handles - dissipative Sturdy, zero backlash box joint Smooth ground gripping surfaces Soft transitions; no sharp edges Low-friction double spring for gentle and even opening The mirror polish together with a fine film of oil offer effective rust protection - no circuit faults caused by peeling chrome from plated tools Narrow sleeves pulled up to the head of the pliers enable the tool to be guided securely and comfortably, also between thumb and index finger With two-colour dual component grips, black/grey Ball bearing chrome steel ESD pliers (electrostatic discharge) electrostatic energy is discharged through the handles in a gradual and controlled manner which protects components endangered by electrostatic discharge in accordance with applicable standards, e.g. IEC TR 61 340-5, DIN EN 61 340-5, SP Method 2472 Article No. 35 12 115 ESD EAN 4003773024835 Head mirror polished Handles with multi-component grips Style 1 B mm 22,5 D mm 7 E mm 1,7 F mm 4,0 A mm 11 Nominal size 115 mm Length mm 115 Net weight g 74 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
35 12 115 ESD 价格&库存
很抱歉,暂时无法提供与“35 12 115 ESD”相匹配的价格&库存,您可以联系我们找货
