70 02 140
70 02 140
    KNIPEX(凯尼派克)
    KNIPEX - 70 02 140 - Cutter, Side, 140 mm, Diagonal, 2.5 mm, 62 °, Knipex - Side Cutters
70 02 140 数据手册
70 02 140 Diagonal Cutter ● ● ● ● ● ● ● Article No. 70 02 140 EAN 4003773023098 Head polished Handles with multi-component grips Style 0 Pliers black atramentized Cutting capacities medium hard wire (diameter) Ø mm 2,5 The indispensable diagonal cutter for all-round use High-quality material and precise workmanship for long service life Precision cutting edges for soft and hard wire Clean cutting of thin copper wires, also at the cutting-edge tips Cutting edges additionally induction hardened, cutting edge hardness approx. 62 HRC Narrow head style for use in confined areas Vanadium electric steel, forged, multi stage oil-hardened Cutting capacities hard 1,8 wire (diameter) Ø mm Cutting capacities soft wire (diameter) Ø mm 4,0 Length mm 140 Net weight g 150 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
70 02 140 价格&库存
很抱歉,暂时无法提供与“70 02 140”相匹配的价格&库存,您可以联系我们找货
