71 01 250
71 01 250
    KNIPEX(凯尼派克)
    KNIPEX - 71 01 250 - Bolt Cutter, Compact, 5.6 mm Max Capacity, 250 mm Overall, CoBolt XL Series
71 01 250 数据手册
71 01 250 KNIPEX CoBolt® XL Compact Bolt Cutters ● ● ● ● ● ● ● ● Article No. 71 01 250 EAN 4003773079637 Pliers black atramentized Handles plastic coated Cutting capacities medium hard wire (diameter) Ø mm 5,6 For powerful cutting of larger cross-sections as well as very hard materials Two-hand operation for maximum cutting force 60 % less effort required compared to high leverage diagonal cutters of the same size 40-fold increase of manual force due to special joint design With gripping surface below the joint for gripping and pulling wires with a diameter as from 1.0 mm Induction-hardened precision blades: cutting edge hardness approx. 64 HRC Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened Straight blades Cutting capacities hard 4,0 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 3,8 Length mm 250 Net weight g 465 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
71 01 250 价格&库存
很抱歉,暂时无法提供与“71 01 250”相匹配的价格&库存,您可以联系我们找货
