74 05 250
74 05 250
    KNIPEX(凯尼派克)
    Cutter, Precision, 250 mm, Diagonal, 4.6 mm, 64 °
74 05 250 数据手册
74 05 250 High Leverage Diagonal Cutter ● ● ● ● ● For very tough, continuous use High cutting performance with minimum effort due to optimum coordination of the cutting edge angle and transmission ratio Precision cutting edges additionally induction hardened (cutting edge hardness approx. 64 HRC), for all sorts of wire including piano wire Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened The 250-mm-long diagonal cutter is suitable for copper conductors up to 16 mm² and aluminium conductors up to 35 mm² 20 % less effort required compared to conventional diagonal cutters of the same length. With integrated forged joint axle. Article No. 74 05 250 EAN 4003773039754 Pliers chrome plated Handles with multi-component grips Style 0 Head Cutting capacities medium hard wire (diameter) Ø mm 4,6 Cutting capacities hard 3,5 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 3,0 Length mm 250 Net weight g 440 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
74 05 250 价格&库存
很抱歉,暂时无法提供与“74 05 250”相匹配的价格&库存,您可以联系我们找货
