86 43 250
86 43 250
    KNIPEX(凯尼派克)
    KNIPEX - 86 43 250 - Water Pump, Plier, Slip Joint, Wrench, 46 mm, Jaw, 250 mm, Length
86 43 250 数据手册
86 43 250 Pliers Wrench pliers and a wrench in a single tool ● ● ● ● ● ● ● ● ● ● ● ● ● Replaces the need for sets of metric and imperial spanners Smooth jaws for damage free installation of plated fittings - working directly on chrome! Adjustable tightening tool Also excellent for gripping, holding, pressing and bending workpieces Push the button for adjustment on the workpiece Zero backlash jaw pressure prevents damage to edges of sensitive components Parallel jaws give a more solid grip; its design allows flexible adjustment of all widths up to the specified maximum size Reliable catching of the hinge bolt: no unintentional shifting The ratchet type principle allows quick and easy tightening and release of all bolted connections Lever transmission greater than 10 : 1 for strong gripping power Chrome vanadium electric steel, forged, oil-hardened 15° angled pliers handle provides space for counter screw connections or bolted fittings on surfaces Reduced risk of knuckle injuries The smooth jaws grip all parallel surfaces in the capacity range with a high degree of pressure if necessary and open up almost unlimited application possibilities for the pliers wrench: e.g. for tightening locknuts, exerting pressure to activate the adhesive power of contact adhesives, edge breaking in tile work, snapping cable ties, utilisation as a small vice. Article No. 86 43 250 EAN 4003773081296 Pliers chrome plated Handles plastic coated B2 mm 8,0 B3 mm 14,0 B1 mm 8,0 Adjustment positions 17 Capacities for nuts Inch 1 3/4 Pliers wrench: zero backlash contact pressure, no damage to edges Conventional open end wrench: edge pressure causes surface damage Capacities for nuts mm 46 Length mm 250 Net weight g 540 technical change and errors excepted Angled handles for more room to grip Spare Parts Article No. EAN 87 09 01 4003773074724 Assortment of spare parts for adjustment for 86/87 250/300 (without 87 2) KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
86 43 250 价格&库存
很抱歉,暂时无法提供与“86 43 250”相匹配的价格&库存,您可以联系我们找货
