88 05 250
88 05 250
    KNIPEX(凯尼派克)
    KNIPEX - 88 05 250 - Plier, Water Pump, Curved, 50 mm Max Jaw Opening, 250 mm Overall Length
88 05 250 数据手册
88 05 250 KNIPEX Alligator® Water Pump Pliers ● ● ● ● ● ● ● ● ● Article No. 88 05 250 EAN 4003773035497 Pliers chrome plated Handles with slim multicomponent grips Head Adjustment positions 9 Capacity for pipes, inches (diameter) Ø Inch 2 Capacities for nuts mm 46 Capacities for pipes (diameter) Ø mm 50 Length mm 250 Net weight g 344 More output and comfort compared to conventional water pump pliers of the same length: 9-notch adjustment positioning for 30 % more gripping capacity Good access to the workpiece due to slim size of head and joint area Self-locking on pipes and nuts: no slipping on the workpiece and low handforce required Gripping surfaces with special hardened teeth, teeth hardness approx. 61 HRC: high wear resistance and stable gripping Box-joint design for high stability due to double guide Robust construction, insensitive to dirt; particularly suitable for outdoor work Guard prevents operators’ fingers being pinched Chrome vanadium electric steel, forged, multi stage oil-hardened With slim multi-component grips without collar for better handling and easier transport Self-locking on pipes and nuts: no slipping on the workpiece; the complete actuating force can be used to turn the workpieces; not having to squeeze the pliers handles reduces the required effort technical change and errors excepted Spare Parts Article No. EAN 88 09 250 4003773053514 Bolt (Kerpin) for 88 250 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
88 05 250 价格&库存
很抱歉,暂时无法提供与“88 05 250”相匹配的价格&库存,您可以联系我们找货
